Bushing A and C print with approximately correct outer diameter (7,96mm) but bushing B comes out about a 0.1 over (8,12-8,13mm)
Seeing that I get a Gap fill on B which probably messes up things.
The bushings are print separately. with the same settings.
Thought I was on to something with keeping measures devidable with the nozzle diameter of 0,4mm, but it did not work in Figure B
Any help would be appreciated.
