That's already easy to do. For example, to insert a pause command at layer 57, just add the command below into your "commands for post-processing" section (on the Scripts tab)jeevesme@hotmail.com wrote:Having a pause command that i could use to insert the pause command at layer X would be awesome. I wouldn't have to keep checking my print every X amount of times to see when i need to manually pause the print on the machine.
{REPLACE "; layer 57\n" "; layer 57\nM0\n"}
That inserts the M0 command right before layer 57 starts, and that will automatically pause the print if you are using USB.
