kabali16 wrote:Did you check the retraction distance ? Are they different for both filaments ? Are you able to print if you only use the PETG extruder ? try printing all the items once with the single extruder first.
I have only seen the PVA nozzle clog often. its strange that it is happening with PETG. Another thing to check is if the extruder has reached the target temperature
I had to re-check all the settings and it turned out that the filament setting for the right extruder was set to 3mm instead of 1.75, once I fixed that it was smooth sailing.
However, I do have a couple issues still..
I use (as far as I know) the same settings in S3D as I use in FlashPrint (the slicer that came with Flashforge dreamer) and printing the same model comes out very differently.
First of all the top doesnt seem to come out completly smooth, but have small holes in it and other artifacts (lines) that are not present with the original program.
Second, there should be a small logo printed on the side of the model, and the original program attempts to print it (even if its small and doesnt come out perfect), but S3D just prints a cut out. (please see attached pictures)
