Is there a way to force an outline of an interior surface to to be printed when its layers are printed on top of fills?
Some filament materials (ex. ABS) need to be printed (attached) to something otherwise it draws back like a rubber band.
I am not sure I described the problem accurately by not differentiating between interior and exterior infills. Shouldn't the green lines ( "exposed surface" exterior infill) have "outline/parameter" lines? The lack of the outline is the problem here because in exterior infill line ends are not anchored to something.brian442 wrote:I'm not sure this is the same issue as the one you are referencing. The OP was asking for a way to put an outline around the infill. I think you're talking about extending the solid fill more.
Either way, these are both extra options and I wouldn't call either a bug. Right now, the software puts solid fill exactly where it should based on the layers around it, but I can see how it would be nice if they offer more options in the future for both of these things (particularly for tough materials that tend to contract a lot more)
@sgertsch - did you get to try the options I mentioned?
BAM, this is a real problem with S3Dsmartavionics wrote:Yet another person gets bitten by the "not extending skins far enough into the infill" bug that the S3D devs have known about for coming on for two years now. People say that the devs read these messages, I don't think there's anyone there at all.
