hi all..got some weird things going on.
A. set the speed to 45mm/s
result, aything from 45 and some where in the region of 80 - 85mm/s randomly happens.(then doesnt then does.)
B. no matter what infill thickness i set it remains the same. (i gave up at 200%) cannot get a water tight top or bottom layer at all.
C. on the posative 45 degree infill extrutions are full and constant.
the negative 45 degree fill 'steps', just before the cross over and stops extruding bang on the cross over at each and every cross over point, looks like stitching. (does not occur any where else bar the one fill area.)
D. a random, ermmm, dunno how to put it, something between a wipe and a prime and a hyper speed 'whip' off to some near locasion. usualy only occuring once or twice, but to no set pattern.
and lastly, is there no Z hop facility?
