lago060
un-orthogonal slicing
hello,
I am working on a "infinite" 3D printer base on the Lum3D http://www.instructables.com/id/The-Loo ... -Assembly/ but it need an un-orthogonal slicing in the Y axis of 45°.
It is possible with the actual version of simplify3d? If no can it be add in a new version ?
brian442
Re: un-orthogonal slicing
Couldn't you just rotate the part by 45 degrees and slice it that way? I think it would create the same result.
