I just loaded my box STL into the program. It puts the "bottom" on the top. I have used the mouse to spin the box around. How do I get the top and bottom to flip? In other words, how do I rotate the other axis?
Thanks
After "drop the table"You can double click on the item and through the window that pops up (you can move it to the side if you want to see the model on the build platform) try adjusting either the X or Y rotation by 180 degrees and you should get a live preview of the rotational effect.
Thanks for that little gem, I always go to netfabb, this is so much easier.danielhenley wrote:The easiest method is to press ctrl-L and chose a face on the model that you want to be flat on the build platform.
Thank you!! Although it would be nice to know how to do this by other means, the CTRL-L worked perfectly for what I wanted to do!danielhenley wrote:The easiest method is to press ctrl-L and chose a face on the model that you want to be flat on the build platform.
