slugbut
prints 1 layer and then prints another copy, I only want one
Another silly question I'm sure.
I'm using a Qidi Tech 1
Printing ABS
I've printed many many prints over the past months.
I've tried to print a simple part this morning and after the first layer it tried to print another copy beside the first..but without extruding any ABS.
The thing is...I only wanted the one copy!!
I thought it was the file so downloaded a calibration cube, the same happened.
I reset the printer to factory settings and reset simplfy.
I tried to print from the USB cable and the SD card... it still tries to print the second and then once on layer 2 doesn't extrude anymore!
THIS IS THE WEIRD THING!
The same file printed on PLA works fine!!
I've checked all the settings on Simplify and the only difference I can see is the temperature of the bed and nozzle. The rest is the same!
PLEASE HELP!!!!
Re: prints 1 layer and then prints another copy, I only want
Why not attach a copy of your factory file for where the double printing is occurring. File menu===>Safe factory file
slugbut
I've worked out why its doing it!!
I just need to find a solution now :)
I added another setpoint line to the Temperature section.
Line 1 is fine and works perfectly
As soon as I add another setpoint, for line 2 it duplicates the print!
Am I adding this wrong?
Thanks all
slugbut
The factory file I used is here
Thanks
xyzCalibration_cube.factory
(5.91 KiB) Downloaded 160 times
Not in front of S3D to be able to look but is the temp set point you added some how pointing the the wrong extruder?
