TDS
Feature request: sub-layer infill/internal support
So I like printing big things with typically a lot of detail. that aren't necessarily undercuts that can be supported.
My only option is to either run really high infill percentages, or have a really high number of outer layers to hopefully have enough support for external details.
My request is this:
you set your infil percentage to be X
However Y layers before the "top" or "bottom" of the part, the infill percentage will be set to Z (thicker) instead
This allows you to not waste tons of material on thick upper layers while correctly supporting them with infill, but not wasting a ton of material on infill of the deeper parts of the model either
