llange
GE Jet engine stator upgrade slicing issue
Hello all !
I'm tring to slice those parts ( http://www.thingiverse.com/thing:410218 ) but S3D is not slicing it fully, only the blades. Even rotating 90 deg. those parts it can't slice correctly
With CuraEngine I can slice correctly. Meshmixer found no errors in those parts.
I'm using layer height of 0,1mm, but even changing it there is no improvement.
Any light ? :D :D :D
Thank you !
brian442
Re: GE Jet engine stator upgrade slicing issue
Is it possible that the hub is thinner than your nozzle diameter? If so, you will need to lower your extrusion width in the software if you want to print it correctly.
I think they talk about it more here:
https://www.simplify3d.com/support/prin ... ng-printed
If it is thin walls, see this thread as well: viewtopic.php?f=23&t=3471
