I already set VERTICAL RETRACTION to my profile to 2mm so everytime my printer goes from one object to another (in the same layer) it raises a bit the Z and then it lowers it.
THE PROBLEM is that the printer does this raising/lowering while also traveling to the other object to strat print it. I would like it to RAISE -> TRAVEL TO THE OBJECT -> LOWER. This should be the case but not, it raises and lowers while traveling. Is it possible to solve this problem somehow?
