Unfated
Spotty first layer...
I'm relatively new to 3D printing. I have a Kossel 2020 Delta printer and was using Repetier but upgraded to Simplfy3D.
The learning curve has been a bit steep. I got everything working now, but am having trouble with the first layer.
It's spotty. As if the printer needs a bit to get the PLA flowing. I was not having this issue with repetier. Am I missing a
setting?
Thank you
brian442
Re: Spotty first layer...
You could try adding a few more skirt outlines, since that will help prime the nozzle more before the part is printed.
There's a few other ideas at the link below that may also be good to check
https://www.simplify3d.com/support/prin ... t-of-print
Unfated
Thank you. I'll try that.
