ViperZ
[ADDED] Prime pillar with changing layer heights
Hi
I use multiple processes and output small things.
0 ~ 0.3 mm → Layer Height 0.1 mm (to obtain strength)
0.3 mm ~  → Layer Height 0.05 mm
However, PrimePillars can not be used.
It is essential to use PrimePillars for cooling.
Thank you.
ViperZ
Re: prime piller
I would like to use the ooze shield as well
Re: prime piller
I am happy to say that this should now work correctly with the newly released version 4.0. You can now use multiple processes with the prime pillar, so if you wanted to have 1 process with 0.1mm layer heights, and a second process with 0.05mm layer heights, that will work fine in version 4.0.
