smeek
Skynet Firmware
Hello, first post here. I am wondering if anyone is using S3D with the Anet A8 Skynet firmware. I am considering installing this firmware. I have been having good luck with the factory file supplied for my printer. Will I continue to be able to use the factory file as is? Will the firmware modifications setting have to changed? Thanks!
MasterFX
Re: Skynet Firmware
I'm using Skynet Firmware on my A8 without any problems. Since it is only a slightly modified Marlin Firmware there is no problem.
You don't have to change any parameters in your Profile which you have used with your stock firmware.
smeek
Re: Skynet Firmware
MasterFX wrote:I'm using Skynet Firmware on my A8 without any problems. Since it is only a slightly modified Marlin Firmware there is no problem.
Thanks!
