drvertigo
How to set secondary nozzle Z-Offset
Hi All,
I have a custom dual extruder printer. The second nozzle is lowered to be below the primary nozzle, when needed.
So I need to set both a Z offset for the second nozzle (2.1mm)
How can I do this?
I am thinking some combination of Gcode in ToolChange Script might do the job, likely with a G92, but am unsure exactly how to achieve this.
Everytime there is a "T1", I need to lower the build plate by 2.1mm, and the opposite when there is a T0. Sadly it is not as simple as just "G91" "G0 Z2.1"
I need something like:
<on T1>
G91
G0 Z2.1
G90
G92 Z[currentZheight - 2.1]
Any suggestions?
Thankyou greatly.
cinpro
Re: How to set secondary nozzle Z-Offset
Have you tried a modifier like
G30 Z0.8 E0; extruder 1
G30 Z0.8 E1; extruder 2
then adjust from there based on results?
Tevo Little MOnster-full Bowden set up
Duet Ethernet running RepRap Firmware
real E3D Titan and Volcano hot end
