Seem to have an issue getting the customize support structure window to show up.
Nothing happens when hitting Ctrl+U or when selecting from the toolbar.
Not sure what the issue could be.
Does not appear in Preview Mode or in Pre-Build mode.
Did you already do this?brian442 wrote:Maybe it's opening on a different monitor. You could try going to help > reset all settings, then open the window after the app reopens. Then it would probably be on the default monitor.
