Hi All,
My first post, I have been using Simplify 3D for a little while now but have hit a particular task that I wan't to achieve in Simplify3D but don't know if its possible exactly as I required.
What I am after doing is being able to adjust the print speed based on the height of the print, the reason being that the bottom of the print is a fairly basic shape but then the top half of the print contains some fine detail (the actual print is a Hot Air Balloon basket where the basket prints easily at 50mm/s but the ropes that attach it to the balloon are fairly detailed and thin, therefore they need to print at about 30mm/s.
I have partially achieved what I want by having 2 processes defined as below:
Basket:
Layer -> Top Solid Layers = 3
Layer -> Bottom Solid Layers = 3
Layer -> Outline Perimeter Shells = 3
Advanced -> Stop printing at height = 18mm
Other -> Default Printing Speed = 50mm/s
Ropes:
Layer -> Bottom Solid Layers = 0 (to stop an additional solid layer being put in when the ropes section starts)
Layer -> Outline Perimeter Shells = 5
Advanced -> Start printing at height = 18mm
My question, is there anything that can be done in S3D to prevent the the solid layer being created from the Basket process having a Top Solid Layers set to 3 as this is required for the inner basket floor?
