....... into a huge giant blob
Am I reading into this that the extrusion is not adhering to your bed and the extruded plastic then accumulated on the print head??
If so, this is probably nothing to do with an updated profile, etc that may be available. Its simply that the nozzle is too far away from the bed when the print starts and its not adhering. If so, this can be addressed by rechecking the bed levelling...either auto or manual. If that has no effect, try adjusting the Global Z offset on the GCode page of the settings......by a negative amount....initially by say 0.05mm and see what the difference is. Adjust until the print adheres, doesn't lift at corners and the bottom of the print is nice and smooth.
See here for more info:
https://www.simplify3d.com/support/prin ... to-the-bed
