Thanks for the information dmulheimer.
dmulheimer wrote:Most slicers allow you to choose one or the other.
So does S3D allow you to chose relative positioning somewhere?
dmulheimer wrote:Also, RETRACT/DESTRING speed is set independently of print speed. So even if you slowed printing down, you could have a high retract speed and that high speed *could* be the culprit due to lost steps. This is what I think CatDog had discovered in your problem.
Watching it print I certainly didn't see anything resembling fast.
S3D does have settings for retract speed and slowing those way down didn't make any difference (listed in my tests). In fact at 100mm /min the x and y axis had to visibly stop and wait for the retract to finish which is why I stopped the test.
And, even if it was missing steps in the extruder, how does that effect the x or y axis?
