I've been using Simplify3D for 6 months or so and I've finally gotten to a point where I'm very happy with my print settings, giving me reliable prints 99% of the time.
So far every time I've used a different filament I use the + button in process settings and create a new profile for that filament. The settings are usually identical (I only print in PETG these days) so I have little need for the multiple profiles, but, it does mean I can tweak a particular one if I need to (let's say a different brand.colour needs a slightly different temp etc).
A few days ago I got my first reel of TPU. I created a new profile in the normal way (select an existing profile and click + to clone it). It needed very few changes to my settings to get a decent print, however I did need to set the extrusion width to auto (I usually have it manually set to 0.5mm) and also reduced the speed to 20mm/s on the 'other' tab.
I've just switched my filament back to PETG and as such changed my filament profile back to the relevant filament profile under process settings. As it's been printing I noticed that it was going very slowly. Now looking in the profile I can see that all my profiles have their speed set to 20mm/s. It seems like changing this setting takes effect across all profiles!
Two questions:
1) Am I managing my filament settings in completely the wrong way? It seems like some setting are mirrored over all profiles. if that's the case how do I know which settings are locked to the profile and which ones persist over all profiles? How do I manage the settings which are mirrored for all profiles if I want a different setting for certain filaments?
2) As I hadn't realised this was going to happen I didn't backup my previous settings and may have tinkered with a few different ones while setting up for TPU. Would the old settings be backed up somewhere like in the header of my old G-CODE files?
I'm hoping the way of managing these settings has improved in S3D 4.0 but currently reluctant to upgrade as I have things setup so that I get very good prints at the moment.
Hope someone can explain what I've done wrong and how I should be managing these profiles for each different roll of Filament.
