blackbird2016 wrote:
making the transition "by hand" from 02mm over a few layers with 0,17mm to 0,15mm.
It as such is working well, skipping the step between by software would be a charm, though...
That's why "mesh modifiers" are bit easier to work with but looks like s3d is going in right direction visualizing processes. if at one time they create a "visual process editor" where you can stack/move/resize processes directly on the part then top/bottom of the process could "snap" to the proper layer's
would be cool to have a "snap" option now (snap to lower or snap to upper position selector would be cool) so you select start/stop of the process and it snaps to proper layer automagically so when you change the layer height you don't have to go and modify start/stop for all the layers too
Embed M117 codes into G-Code
open source and unlicence
