JWest
[SOLVED] Strange issues with FF Creator Pro toolhead jogging
Hi All,
I am suffering some strange issue with the Machine Control Panel. I am using a FF Creator Pro 2015.
If I select tool head 0 then everything works as expected.
If i select tool head 1, things go weird when on manual control:
X, Y, Z does not move in the selected size step, they move a large set amount.
X,Y,Z does not pay any attention to the speed control, moving very quickly instead
Extruder does not extrude if the x-axis is not at home, the carriage will move along using the extrude button until it hits home, then it will start extruding.
brian442
Re: Strange issues with FF Creator Pro toolhead jogging
There's a long-standing bug with most x3g firmwares that does odd things when you try to jog wth T1 selected. So if the issue only happens when you have T1 selected, then I would be pretty certain that's what you are seeing.
Unfortunately, I don't think there is a firmware fix yet, so just something to be aware of
JWest
Ok, I was unaware of this, thanks for letting me know ;)
