Ayres3D
Re: Turn off printer lights?
Tue Aug 15, 2017 3:29 pm
dkightley wrote:As has been said earlier in the thread, if your printer and firmware support a command to turn lights on or off, you can add the relevant command into your ending script. S3D has the capability to allow commands to be included....so if your printer will accept an instruction.....then S3D will be able to give it! You just need to find out what it is.
That's my problem. I know the theory of how to do it, what I don't know is the precise command. Hence the request. I also know that it must be possible as ReplicatorG can do it. I'm just missing the specific information about the code for the FFCP and I was hoping that someone would have done it already and could tell me the command string which worked for them.
