dorsai3d
Re: S3D version 3.1 error in Fedora Core
I ran into this went as well, and went ahead and emailed support about this to see what they were saying. They provided a dropbox link to the correct file: https://www.dropbox.com/s/rbs5b3td76x62 ... t.zip?dl=0
Their response for completeness' sake:
Thank you for contacting Simplify3D support. I'd be happy to assist you with your install on Fedora. The Fedora developers have decided to handle their version numbering differently than other major distributions. To use the software on Fedora, please download the file linked below, unzip it and copy the resulting file to the Simplify3D install directory (typically /opt/Simplify3D-3.1.1).
After you have this file in the Simplify3D install directory you should then be able to run the included launch script and successfully launch Simplify3D. For example, open a Terminal window and type:
cd /opt/Simplify3D-3.1.1
sudo ./LaunchScript.sh
These changes have now been incorporated into the latest 4.0.0 software release. This will resolve any openssl or libcrypto issues mentioned in this thread. We have tested this version on the latest Fedora, Ubuntu, Debian, Arch, and several other distributions and it should work out-of-the-box without any further changes.
Thank you for reporting the issue!
