zappa79
Weird lines
Does anyone know why I get these weird bandings or what ever they are called?
Re: Weird lines
I think that is the layer stop/start points. You may be able to change the start point setting and see if it makes a difference.
arhi
Re: Weird lines
only one axes? only one wall? or you get them on all axes and all walls?
this looks like a microstepping issue some drivers have at lower speeds so they skip steps, depending on your driver solution vary (if that's the culprit), for drv8xxx you need to add few external diodes, for alegro you need to switch it to "always mixed decay" ..
Embed M117 codes into G-Code
open source and unlicence
zappa79
Re: Weird lines
wirlybird wrote:I think that is the layer stop/start points. You may be able to change the start point setting and see if it makes a difference.
Layer start stop?
I am realatively new to 3D printing, would you be so kind to help me out a bit more? how do I do that?
Re: Weird lines
In the Settings Layer tab there's a section headed Start Points. The descriptions are self explanatory and if you hover on the radio buttons for a second or two then tooltips will appear that give a little more info.
