yonkiman
Variable Settings Wizard and Temp Towers
With 4.0, I now can easily slice a temp tower into multiple heights with their own processes. But I have to manually go in and change the temperature for each process. And the temp window wants to know the layer. But the slice positions are in mm.
So do I have to look up where each slice of the layer begins (in mm), then divide by my layer height to get layer number, and enter the new temp at that layer?
Or is there an easier way that I'm missing (like a "global" temp for each process)?
It seems like the easiest way is still the way we did it in 3.x - calculate layer for each temp transition and enter them all into one process.
darKing
Re: Variable Settings Wizard and Temp Towers
Isn't the temp of the 1st layer of every process the one you're looking for? I really can't recall if it ocurred so natural to me and just worked, or if I never actually tested it. :mrgreen:
