atlemo
Nozzle crossing top layer making scars
I'm sure this has been discussed before, but I could not find any threads on it – so I'm sorry if this is a repeat.
Now, I'm getting lines in my top layers because the nozzle is crossing over, leaving these ugly lines/scars. Is there any way to avoid this, with a z-lift on travel or similar?
See example:
jfkansas
Re: Nozzle crossing top layer making scars
It won't make scars as bad if you are extruding the proper amount of plastic. Since that top layer is overextruded about 10-15% the nozzle drags through the high spots leaving scars. Or is there a second nozzle that might be too low? Both will do it, but having a hot nozzle go through over extrusion is much better than a cold one. At least the hot nozzle will melt its way through.
You've answered your own question....
Use Retraction vertical lift to lift the nozzle ( actually lower the bed ) before travel moves. You'll need retraction switched on of course..but I assume you'll already be using it!
brian442
There are also some good tips here:
https://www.simplify3d.com/support/prin ... op-surface
In particular, make sure you aren't extruding too much plastic, because that will only make things worse!
atlemo
Ah, thanks guys! I had forgotten to disable "Only retract when crossing open spaces".
