MikeD wrote:3Drasle wrote:Hi Rob
I use it for my own designed printer. Build area aprox 500x350x450 mm (WxDxH)
Board and stepperdrivers is MakerBOT gen.4.
I use both Simplify3D and KISSlicer
Hi Mike
Thread Hijack (kind of)
i have a makerbot gen4 type of printer and still trying to get everything running properly
i'm curious if you have done anything for start/end scripts
Hi Mike
scrips is below. They are full of garbage i newer removed but work fine for me.
I only have endstop on my Z axis. Hope you can use some of it.
START:
(**** beginning of start.txt ****)
(**** begin initilization commands ****)
G21 (units=mm)
G90 (positioning=absolute)
M104 S225 T0 (extruder temperature)
M108 S255 (extruder speed to maximum)
M103 (Make sure extruder is off)
M109 S110 T0 (heated-build-platform temperature)
(**** end initilization commands ****)
(**** begin homing ****)
(G161 Y F4000 (home Y min))
(G161 X F4000 (home X min))
G161 Z F1000 (home Z axis min)
G92 Z-0 ( ---=== Set Z axis min ===--- )
G1 Z5 F1000
G161 Z F50 (home Z axis min)
G92 X0 Y0 (set zero for X and Y)
G92 Z0 ( ---=== Set Z axis min ===--- )
(**** end homing ****)
(**** begin pre-wipe commands ****)
G1 Z10 F1000
G1 X120 Y120 F3000 (ventepos)
G1 Z0 F1000
M6 T0 (wait for nozzle
HBP
etc.to reach temperature)
G92 E0
M106
M107
END:
(**** Beginning of end.gcode ****)
(This file is for a MakerBot Thing-O-Matic)
(*** begin settings ****)
(**** end settings ****)
(**** begin move to cooling position ****)
G1 X0.0 F3300.0 (move to cooling position)
G1 X0.0 Y80.0 F3300.0 (move to cooling position)
(**** end move to cooling position ****)
(**** begin filament reversal ****)
M108 R1.98 (set extruder speed)
M102 (Extruder on
reverse)
G04 P2000 (Wait t/1000 seconds)
M103 (Extruder off)
(**** end filament reversal ****)
M18 (Turn off steppers)
(**** begin eject ****)
(**** end eject ****)
(**** begin cool for safety ****)
M104 S0 T0 (set extruder temperature)
M109 S0 T0 (set heated-build-platform temperature)
(**** end cool for safety ****)
(**** end of end.gcode ****)
