I've been having issues with poor vertical strength on screwholes near the edge. I was watching and even though I'm at 40% infill, it's not printing infill as it build the vertical outside edge between the screwhole and the outer edge.
In Slicer, there's a setting called "Solid Infill threshold area" you can set low enough to make small areas like this forced to have infill for strength or when the infill density is too low to put anything in it. I can't find any setting like this on S3D and it doesn't seem to me something as simple as this would just be left out. Where is this setting?
