JD95
Gaps between perimeters and infill visible in g code
In a part I was making today, I found areas where material wasn't being placed, leaving unwanted one-bead gaps between surface infill and perimeters, where interior infill wasn't being placed like it should have been, or better yet, the "top" layer extended to the perimeter.
25mm cubic bucket.gcode
(158.94 KiB) Downloaded 352 times
25mm cubic bucket test.factory
(5.35 KiB) Downloaded 246 times
JD95
Re: Gaps between perimeters and infill visible in g code
Separate STL in case it's needed. See above post for the factory file.
25mm cubic bucket.stl
(15.61 KiB) Downloaded 257 times
Set your perimeter/shells to 4.....or change infill to 100%
Your "gap" is the 50% infill that is not being filled because there's only one filament with available.
JD95
It does the exact same thing at 0% (oops duh on me), 10%, 30% and 100% infill, and probably everything in between.
I can add perimeters but I think it's a workaround. It's a situation that I would appreciate it if the slicer can avoid doing in the first place. It seems to be a bug that pops up only when the remaining gap for interior infill is one bead width wide or narrower.
