New to Simplify3D software but have been printing for a year or so.
Gcode outputs fine, produces a 31 meg file. Load the SD card into Monoprice Select Mini and start the print. Bed heats up, extruder heats, up, progress bar on display says it's 3/4 the way through a 10 hour print even though I started the print 10 minutes ago. And no movement of any axis at all. Ideas? Gcode file attached if someone has the time to look at it and see what I've done wrong. Pretty much using the default profile for this print, tweaked the infill a bit to avoid a few holes due to no internal support.
Ran the same model through Cura and it works. So it's definitely an S3D issue or most likely my settings.
