OldRick
Re: If Simplify 3D version 2.1.0 is CRASHING when you "Prepa
I've also had the same 2.1.0 crash on Prepare when using Random Start Points on Mac 10.9.2.
I'll continue using Cura and Kisslicer for now - you only get one crash per version. I'm no longer in the SW debugging business, and haven't got time for this.
3ntrlab
Sadly, I must agree: going back to Kisslicer.
I am suffering crashes when I am trying to save the Gcode of large prints.
Will use S3D just for small jobs.
Best Regards
Davide Ardizzoia
Professional 3d printers : http://www.3ntr.net
LeonMF
Same crash here on randomize starting points.
OSX Mavericks, 2012 MBP Retina.
sperea
S3D is crashing for me regardless of profile selected, settings changed, or .stl file used. Anytime I hit Prepare print, the program stops and must be closed. It is set to print to a LeapFrog Creatr dual. Version 2.1, running on 64 bit Windows 7 home premium.
thepolekat
Crashing on "Prepare to Print!" for me as well with "Use random start points for all perimeters" turned ON as well. Locks up, have to restart the program.. Using Windows 7 (64 bit) with FlashForge Creator Dual.. :(
joesoap583
I have been suffering the same problem when attempting to prepare for printing - I get a popup program exception advising that Windows is going to try to find a solution, which then aborts.
The problem appears to have been fixed by turning off the random start points as advised above. v2.1.
Posting as a private individual - 3D printing is a hobby activity.
Creality CR-10S owner.
AndersE
I have the same bug.
A tip is to exit the program before hitting prepare. If it crashes you just need to start the program again. It starts automatic with the last loaded objects and settings.
So you don't have to load the objects and placements again.
ve3sjk
Also had this crashing issue on some files and on one machine in particular it was all the time when i hit the build no matter the settings. I resolved this is by changing the video drivers on that laptop. If you have a laptop or machine with Intel HD3000 based video controllers, make sure you have the absolute latest driver installed for it. In my case the laptop was Acer 5755 I7, Acer driver provided for video from their site caused crashing, the update from Intel site fixed it.
here is my crash report, the key here is the DLL file ig4icd64.dll which is the video driver.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Simplify3D.exe
Application Version: 0.0.0.0
Application Timestamp: 5341934b
Fault Module Name: ig4icd64.dll
Fault Module Version: 8.15.10.2372
Fault Module Timestamp: 4da88312
Exception Code: c0000005
Exception Offset: 00000000007bc401
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: ee1a
Additional Information 2: ee1a2f1fa869bd34e1a477101878b85c
Additional Information 3: d374
Additional Information 4: d3745985d597134d2d4bb6ac5f72e30a
joesoap583
ve3sjk wrote:Also had this crashing issue on some files and on one machine in particular it was all the time when i hit the build no matter the settings. I resolved this is by changing the video drivers on that laptop. If you have a laptop or machine with Intel HD3000 based video controllers, make sure you have the absolute latest driver installed for it. In my case the laptop was Acer 5755 I7, Acer driver provided for video from their site caused crashing, the update from Intel site fixed it.
To be honest NO software program should fail catestrophically due to some shortcoming in the users hardware/software environment. An error such as this should be caught and dealt with gracefully - not by dumping the user out to the operating system.
From the popup dialog that appears this bug appears to be captured by the operating system. That's too late - the user might have wanted to save their work or something. It's kinda like your car putting up a message that you need to apply the brakes - after you've hit the brick wall.
I'm sure the resolution to this (e.g. extra error trapping) will be easy enough for the author.
Hermannus
naturally i had these crashes also. (why else would i reply)
I tried every recommended setting, but the only thing that helped me, was updating the video-driver(s)
Win7-64 with Intel HD Graphic 3000 . After updating driver, no more crashes.
Thnx ! :D
