Max2206
Print Quality problems
Hi, I hope someone can help me i'm sending my S3D settings for ESUN ABS filament 1.75mm
My printer is the TEVO Tarantulla XL
I'm not really happy with the result of my prints
Look at my photo's of the XYZ calibration cube, can you see the problems.
What can i do to have some better quality in my prints.
All info is happely accepted
Marnix
INFO ...
GCODE start script (bed heating is automatically done by S3D))
G28 X0 Y0 Z0 ; Home all
G29 ; Bed leveling with BLTouch
G1 Z5 F1000 ; Slide the probe back in
G1 X10 Y10 F6000 ; Move to start of bed
M109 S[extruder0_temperature] ; Set extruder temp and wait to be reached
G1 Z0 ; Go to Z0 with offset included
G1 Z0.1 F1000
G92 E0
G1 X6.0 F2000
G1 Y60.0 E4.0 F1000.0 ; prime
G1 Y100.0 E8.5 F1000.0 ; prime
G92 E0
GCODE end script
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
G91 ; use relative coordinates
G1 Z20 F5000 ; lift nozzle by 20mm
G90 ; use absolute coordinates
G28 X0 ; home X axis
G1 Y255 ; move Y axis to end position
M84 ; disable motors
M107 ; turn off fan
Additional terminal commands for post processing
{REPLACE "; outer perimeter\n" "; outer perimeter\nM204 P1000\n"}
{REPLACE "; inner perimeter\n" "; inner perimeter\nM204 P2000\n"}
{REPLACE "; solid layer\n" "; solid layer\nM204 P3000\n"}
{REPLACE "; infill\n" "; infill\nM204 P4000\n"}
20171013.rar
XYZ Calibration Cube Photos + S3D settings (screenshots)
(7.01 MiB) Downloaded 279 times
joaojoao
Re: Print Quality problems
well, can´t help you much, but isn´t it a temperature or extrusion rate issue?
mckinnonk
I don't print in ABS, but here are some of my opinions.
Bed Temp seems really high
Speed is far too high
Cooling should be on.
Try turning cooling on 50%, and slow that print down.
