Hi. I'm attempting to print a block from which a strap (approximately 1/16"x0.5"x6") protrudes from the center of one face. The strap requires support material under the 0.5" wide face above the build plate. I'm using a MakerGear M3 printer.
This printed fine in PLA, but over time occasionally the strap would break off - despite fillets where it joined the block. S3D Tech Support informed me that PLA is one of the more brittle filaments and recommended PETG as a more flexible alternative. I liked their idea because my print would be less likely to deform if subject to direct heat from the sun, etc.
After attempting to follow Jules' very helpful eSUN Black PETG recommendations on MakerGear's "Filament" sub-forum, I was able to get a very nice print... EXCEPT that the strap portion's outline shell layers delaminate completely from the its infill (almost like they were never bonded together at all), and it's next to impossible to separate the high-density support material generated below the strap.
I've experimented with many of S3D's settings (e.g. Infill Overlay, Extrusion Multiplier, Infill Extrusion Width, etc.) and I've followed recommended settings to optimize PETG bond strength (e.g. no fan, hot end = 242C), but I can't seem to get the outline shell layers of the strap to bond to each other or to the infill area. I'm also getting fine hairs, but I can live with that for now. There doesn't seem to be any delamination problem at all with the shell layers on the block, but the bonds on the strap are extremely weak and any flexing at all - including vain attempts to remove support material - causes the outer layers to separate.
Any suggestions toward achieving a strong bond in these shell layers and/or separating the support material would be greatly appreciated. Thanks! - guy
