Sylvian
Re: Support for Prusa i3Mk2 with Multi Material Upgrade
Hi, there, most of Prusa users has now receive their multimaterial upgrade, as many others I've to use the software provided by prusa, And results are really lower than S3D, is it possible for you to just give an answer ? Are you going to try to update ?
Thanks for reading, regards, Sylvian.
4truemodels
Sorry to disturb you all but... Have you tried to contact Prusa company as well for help?
If you only need some script to work everything propperly maybe the one that should care about that is the Prusa manufacturer. However, if you need further changes like new options and arrangements rather than just a script then Simplify3D should care about all of these too.
I mean no offense at all, just want to help you all too by pointing that maybe the Prusa manufacturer itself could be of much more help with this.
NealWeeks
Just to add my $.02 I would really like to see this also. I really like the fact that up to this point S3D has been my "one stop to shop" for 3d printing. Please make this available.
HKOCH
I would like this too. I prefer using Simplyfy3D but now can't anymore :(
yetisnack
Add me to the list of users waiting patiently for official support of the MMU. No matter how I tweek the settings in Slic3r, I still can't get as nice a print out of it as I can with S3D. My MMU came this week and I'm holding off on installing it until S3D supports it.
Mastabi
Also I would be very pleased if the MMU is supported by S3D.
FAISANS
Hi, everyone, ok the MM Prusa is in production since many month.
The absence of care in this software should be considered as a big problem.
best regards.
dparkins
I would like to see this as well.
ir_fuel
Another Prusa mmu user here!
Would love to use it with S3D
Bettsy77
I also still wating fot the MMU Solution :(
