I'm printing, starting with a STL file from OpenScad. I used 3 processes to adjust the infill for the first 1.7mm, the next 1.2mm, and then the rest. Layer height was 0.1mm. I printed another very similar model, and managed to screw up the process settings and the print has problems.
I thought I'd look at the G-code for the first good print and see what the settings I used were. It looks like only the settings summary for the first process ended up as comments in the G-code, instead of all 3 processes I used to create the G-code.
Is there a way to turn on more details in the G-code in case I make a similar error in the future? Otherwise, I'd say this is a bug.
Simplify3D version 4.0.0. Windows 64-bit.
