Hi
I'm a newbie to 3d printing and wonder if any one could possibly help.
I purchased and built an Anycubic Kossel Linear Plus 230mm dia by 300mm height.
The manual gave settings for use in Cura but the setting parameters don't seem to match the S3D parameter's directly.
I printed a test piece using Cura and cant get it to print out a respectable part.
Would you be able to advise what to use in the configuration assistant?
Or ideally does anyone have an fff file they use, they wouldn't mind sharing.
I'm sure the fff will need tweaking to get it right for my printer but at least I will have a good base to work on.
After selecting a circular base .....
I understand that my build volume for X and Y should be 0.707 x 230mm dia = 162.6mm.
And the offset should be 162.6mm / 2 = 81.3mm for X and Y.
I intend to read up on all these settings and try and understand it all.
But I like a new kid in a sweet shop and what to print some plastic.
Would be very grateful of any assistance.
Best regards
Andy
