tana4
G-code M107
Does it ever use s3d in the generated g-code M107?
Or just M106 S0.
brian442
Re: G-code M107
I think those 2 commands do the same thing, so you could probably use either one.
But anyways, you can also change it by going to Tools > Firmware Configuration, clicking on the FFF tab, and editing the "Fan Off" command.
Re: G-code M107
It's an old command not used in some firmware so use M106 S0 now.
tana4
Re: G-code M107
Thank you.
I want to use the M107 for another function. I wanted to be sure M107 s3d was not used.
