You helped me figure out my last issue, so hopefully you can help me with this one. I'm using a robo r1 plus with simply3d, my issue is when I print something with supports the first layer after the support is crappy. I've been playing with settings on the support side but have had no luck. here are the support settings I have.
Support infill: 30
Extra inflation distance: 1mm
support base layers 0
combine support every 1 layer
dense support layers 4
dense fill: 90%
support pillar resolution 1mm
horizontal offset from part: .30mm
upper and lower vertical seperation layer 1
