There's a feature to start the print at a set height under the advanced tab...
I think this is an excellent feature as if you catch a print that's about to fail, you can stop it, fix the problem and resume printing.
However, instead of specifying this height in mm, can we also have the option to choose the layer... so start at a defined layer.
And one final thing is this option has a bit of a bug... So say you tell it to start printing at 3mm... it carries out the starting gcode and priming but then the extruders start moving into position before the build plate has moved into position causing it to collide with the part.
Can you please change this so that the platform moves into position first before the extruders move to prevent this... because of this collision, I had to manually align the platform again (glass plate held by clips) which will not be a perfect alignment...
Cheers
