How can I prevent the printer from reversing the direction while making a print of a small, hallow cylinder?
I'm using a Qidi Teach 1 which uses Makerbot instructions.
I'd like the printer to use corkscrew motion as in vase mode, but make a thicker wall.
Using the setting "merge all outlines into a single solid model" fixes the revercing problem, but it also makes a solid fill.
Is there a way to tell the the slicer to keep circling in the same dirction instead of revercing with every layer?
The revesing motion makes a seam effect.
