I can't seem to find a way to un-split a process once it's been split. I've tried going back to the Variable Settings Wizard to remove , because I remembered seeing a "Remove Location" button there, but there is no location listed to remove. The object forever after is split at that point. Deleting the processes and applying a new one doesn't get rid of the split (because, I guess, it's really the object that gets split, not actually the process), and neither does deleting and re-importing the object. It still will only print up to where the split used to be.
Do I just have to throw out the whole factory file and start from scratch? What am I missing?
