Does anyone else find the profile management a bit annoying.
I have a duel extruder and I have several types of plastics. So I'd like a profile for
1) left plastic 1
2) left plastic 2
3) right plastic 3
4) right plastic 4
etc.
The issue is, if I create a profile, tweak it, then
create a new project/object and want to use a different process, if I've changed anything with the first process asks you to export it. Couldn't it just save the settings on that profile the way they were?
If you don't re-export it you lose your settings on that profile. OK, so fine, you decide to re-export it.
Now you go to your 1st profile tweak etc to print an object and you have to repeat the annoying save process to go back to the 2nd profile.
Ok so you annoying export again so you don't lose stuff.
Now you decide to go back to profile two again. The settings aren't the ones you exported though, they're the original ones. So if you want your tweaked settings you have to import again. Well now you have two profiles when you really just wanted one.
Uhgggg.
Seriously needs a usability revision.
This isn't too big an issue if you just changed your infill and support settings (just ignore and lose them and reset them next object anyway) but it's a pain in the ** if you are trying to calibrate your extruders and are switching back and forth between the processes.
