marekety
gcode generated by Simplify is not Sindoh supported file
I use Sindoh 3DWOX typ 3DP200A. In Configuration Assistant Sindoh 3DWOX is set. Despite this, when I insert gcode file generated by Simplify, I receive
information: this file is not supported by Sindoh.
Help me, please
Marek
Rittic
Re: gcode generated by Simplify is not Sindoh supported file
Same problem. I contacted support. Seems like 6 months with no reply nor resolution is a bit of a long wait.
Sindoh D200A printer. Export GCode to 3DWOX yields nothing. The file doesnt load. I am trying to use Simplify as some of my more complex models the 3DWOX slicer doesnt work with.
lil help would be nice
I would also LOVE to be able to print from over the network. Your software has it as an option, yet my only provided means of printing are over USB or to a disk. Yet I have a network cable and the printer on my network.
Please advise to both
Thanks!
This is not really the place to ask such questions and expect an official reply. This is a user form.....not a support forum! SImplify3D do read what is posted...I assume to get a feel of the mood of the user base, but they post officially on very rare occasions.
Best thing is to email the support email address....and keep badgering them for an answer if they don't respond!
greybeard
Yes, it would be good if software was updated and worked well. But, until then, this might help...
You're going to Cut & Paste, as follows - this is done by common-sense inspection and iteration until you get what works. It took only a few minutes when I needed to do it early-on, before s3d had a process for my first printer:
DoubleClick your process (almost any process will be okay but look for one you think closely matches that for your printer but, don't worry about it as long as the Bed size and other physical attributes are correct....). Do this after you set the printing parameters (layers, shells, nozzle, Temp...etc) in the process.
Select the Scripts tab
In the lower section, change the Post Processing Format to Standard G-code
Run the process and save the output to disk
Open one of your 'known to work' G-code files from, perhaps, a demo that came with your printer. Typically, they are Text Files with some extension but, a TextEditor should open them. If needed you can change the file extension to .txt
Look at all of the lines above the actual G-code operations - your's may all start with a " ; " or other 'comment' indicator.
Copy all of the lines above the actual G-code operations.
Compare these copied lines to those in the saved output. You may need to modify some, depends... Inspect these lines for conflicts between them and the lines in your Demo file. Adjust as needed. Recognize the demo file may have different settings from what you wanted for this new process so, change them.
Paste the copied/tweaked lines into the saved output file
Now, here's the trick I discovered when I needed to do this - it was only the first Three lines that needed replacing! Those lines called out the Printer, Model and Brand. All of the other lines in the Saved Output file worked.
Thus, some review and comparison may result in only a few lines needing tweaking...
good luck
3D Print Parts
grxjohns
Simplify3D Support advised me that the warning "just indicates that the file is not from Sindoh's slicer. You can safely ignore it and print without issues." I've followed this advice on my Sindoh 3DWOX1 and found that the Simplify3D gCode does indeed work fine. I had no significant issues with the machine or the print. So if you get the following notification on your Sindoh you can just ignore it ...
cmadson
I just picked up a Sindoh 3DWOX DP200 running the AQ firmware. I got sick of the error message when printing from S3D. I wrote a VERY rough python script that removes the error and provides the default functionality such as time, build size, thumbnail image and percent bar progress. It also removes the error when you start printing.
Copy and paste the following code into a text file with a .py extension.
Install python
At command prompt >>python3 code.py
Good luck!
# SIMPLIFY3D to 3DWOX
# Carl Madson
# [email protected]
# December 30, 2023
# In S3D under Edit Process Settings, Output Tab, check Include Thumbnail Images
# Thumbnail Encoding: Octoprint, Klipper....
# Default size of 300x300 seems to work fine
# My apologies for this being rough and inefficient, not my most elegant code
# December 31, 2023
# Cleaned up the code A LOT, used objects, added raft layers
# Also need to clean up find first int/float functions
import base64
import math
import re
import tkinter as tk
from tkinter import filedialog
TK_SILENCE_DEPRECATION=1
def pick_file():
root = tk.Tk()
root.withdraw() # Hide the main Tkinter window
# Show the file picker dialog
file_path = filedialog.askopenfilename() # Returns the selected file path or None
root.destroy() # Close the Tkinter window
return file_path
file_path_in = pick_file()
tmp = file_path_in.split('.')
file_path_in_noext = tmp[0]
file_path_out = file_path_in_noext + "_3DWOX.gcode"
S3D_in = open(file_path_in, "r")
W3D_out = open(file_path_out, "w")
class printObject:
tsl = 80 #thumbnail string length
header = ";3DWOX Desktop Version : 1.4.1157"
gcode = []
ss = []
bs = []
thumbnails = []
ssdict = {}
name = ""
material = ""
raft_layers = 0
xyadj = 0.0
hours = 0
minutes = 0
length = 0.0 #mm
volume = 0.0 #mm^3
weight = 0.0 #grams
cost = 0.0 #unitless
po = printObject()
# FIND_FIRST_INT
def find_first_int(string):
match = re.search(r'\d+', string)
if match:
return int(match.group())
else:
return None
# FIND_SECOND_INT
def find_second_int(text):
matches = re.findall(r'\d+', text)
if len(matches) >= 2:
return matches[1] # Return the second match
else:
return None
# FIND_FIRST_FLOAT
def find_first_float(text):
# Regular expression for matching a floating point number
match = re.search(r'\b\d+(\.\d+)?([eE][+-]?\d+)?\b', text)
if match:
return match.group()
else:
return None
# DETERMINE_BUILD_SIZE
def determine_build_size(po):
min_x = min_y = float('inf')
max_x = max_y = float('-inf')
is_part_started = False
for line in po.gcode:
if '; feature outer perimeter' in line: # Placeholder for part start marker
is_part_started = True
if is_part_started:
if line.startswith('; layer ') and not line.endswith('end'):
po.layers = find_first_int(line)
tmp = line.split(',')
po.zmax = round(float(find_first_float(tmp[1])),1)
if line.startswith(('G0 ', 'G1 ')) and 'E' in line: # Movement with extrusion
parts = line.split()
for part in parts:
if part.startswith('X'):
x = float(part[1:])
min_x, max_x = min(min_x, x), max(max_x, x)
elif part.startswith('Y'):
y = float(part[1:])
min_y, max_y = min(min_y, y), max(max_y, y)
# Calculating dimensions
po.width = round(max_x - min_x,0)
po.depth = round(max_y - min_y,0)
return po
# GET_BUILD_SETTINGS
def get_build_settings(po):
for line in po.bs:
if line.startswith('; Build Time:'):
po.hours = int(find_first_int(line))
po.minutes = int(find_second_int(line))
if line.startswith('; Material Length:'): #mm
po.length = float(find_first_float(line))
if line.startswith('; Material Volume:'): #mm^3
po.volume = float(find_first_float(line))
if line.startswith('; Material Weight:'): #g
po.weight = float(find_first_float(line))
if line.startswith('; Material Cost:'):
po.cost = float(find_first_float(line))
return po
# BUILD_SYSTEM_SETTINGS_DICT
def build_system_settings_dict(po):
for line in po.ss:
pos = re.search(r'\w', line)
if re.match(r';\s+\w+,\w+', line):
key, value = line[pos.start():].split(',', maxsplit = 1)
if value.isdigit():
value = int(value)
elif re.match(r'^-?\d+(\.\d+)?$', value):
value = float(value)
po.ssdict[key] = value
return po
# DETERMINE_SYSTEM_SETTINGS
def determine_system_settings(po):
po.material = po.ssdict['autoConfigureMaterial']
po.name = po.ssdict['targetModels']
tmp1 = 0
tmp2 = 0
if po.ssdict['useSkirt']:
tmp1 = po.ssdict['skirtOutlines'] * (po.ssdict['firstLayerWidthAbsolute'] * (po.ssdict['firstLayerWidthPercentage'] / 100)) + 0*po.ssdict['skirtOffset']
if po.ssdict['useRaft']:
po.raftLayers = po.ssdict['raftBaseLayers'] + po.ssdict['raftTopLayers']
tmp2 = po.ssdict['raftOffset'] + po.ssdict['raftSeperationDistance']
po.xyadj = 2 * max(tmp1, tmp2)
return po
# EXTRACT_DATA
def extract_data(po, file_handle):
is_thumbnail_section = False
thumbnail_data = ""
is_gcode_section = False
is_bs_section = False
is_ss_section = False
for line in file_handle:
# THUMBNAIL start
if line.startswith('; thumbnail begin'):
is_thumbnail_section = True
thumbnail_data = ""
continue
if line.startswith('; thumbnail end'):
# Decode and store the thumbnail data
try:
decoded_data = base64.b64decode(thumbnail_data)
po.thumbnails.append(decoded_data)
except base64.binascii.Error:
print("Error decoding base64 data")
continue
if is_thumbnail_section:
newline = line[1:]
thumbnail_data += newline.strip()
continue
# GCODE start
if line.startswith('G90'):
is_gcode_section = True
if is_gcode_section:
po.gcode.append(line.strip())
if line.startswith('M84') and is_gcode_section:
# BS Start
is_bs_section = True
if is_bs_section:
po.bs.append(line.strip())
# SS Start
if line.startswith('; G-Code generated by Simplify3D'):
is_ss_section = True
if is_ss_section:
po.ss.append(line.strip())
return po
# WRITE_GCODE
def write_gcode(po, file_handle):
file_handle.write(f"{line}\n")
# WRITE_SS
def write_ss(po, file_handle):
for line in po.ss:
file_handle.write(f"\n")
# WRITE_HEADER
def write_header(po, file_handle):
file_handle.write(f"\n{po.header}\n\n")
# WRITE_THUMBNAILS
def write_thumbnails(po, file_handle):
for index, thumbnail in enumerate(po.thumbnails):
encoded_thumbnail = base64.b64encode(thumbnail)
decoded_string = encoded_thumbnail.decode("utf-8")
rows = math.ceil(len(decoded_string) / po.tsl)
for i in range(1, rows+1):
write_string = decoded_string[(i-1)*po.tsl:i*po.tsl]
file_handle.write(f";IMAGE[{i}/{rows}] {write_string}\n")
# WRITE_SINDOH
def write_sindoh(po, file_handle):
filename = "f{po.name}"
encoded_filename = base64.b64encode(filename.encode())
file_handle.write(f"\n;FILENAME[1/1] {encoded_filename.decode('utf-8')}\n\n")
file_handle.write(f";PRINTER_MODEL: [DP200]\n")
file_handle.write(f";ESTIMATION_TIME: [{po.hours}:{po.minutes}:00]\n\n")
file_handle.write(f";DIMENSION: [{po.width}:{po.depth}:{po.zmax}]\n")
file_handle.write(f";LOCATION: [89:84]\n")
file_handle.write(f";OPERATINGZONE: [31:32:5]\n\n")
file_handle.write(f";CARTRIDGE_COUNT_TOTAL: [1]\n")
file_handle.write(f";USEDNOZZLE: [1]\n")
file_handle.write(f";CARTRIDGE_USED_STATE: [T]\n\n")
file_handle.write(f";ESTIMATION_FILAMENT_CARTRIDGE_0: [{po.length}]\n")
file_handle.write(f";MASS_CARTRIDGE_0: [{po.weight}]\n")
file_handle.write(f";MATERIAL_CARTRIDGE_0: [{po.material}]\n")
file_handle.write(f";ESTIMATION_FILAMENT: [{po.length}]\n")
file_handle.write(f";MASS: [{po.weight}]\n")
file_handle.write(f";MATERIAL: [{po.material}]\n\n")
file_handle.write(f";TOTAL_LAYER: [{po.layers}]\n")
file_handle.write(f";TOTAL_RAFTLAYER: [{po.raft_layers}]\n")
file_handle.write(f";TOTAL_MASS: [{po.weight}]\n\n")
# MAIN
po = extract_data(po, S3D_in)
po = build_system_settings_dict(po)
po = determine_system_settings(po)
po = determine_build_size(po)
po = get_build_settings(po)
write_header(po, W3D_out)
write_ss(po, W3D_out)
write_thumbnails(po, W3D_out)
write_sindoh(po, W3D_out)
write_gcode(po, W3D_out)
S3D_in.close()
W3D_out.close()
EduMerch
I´m testing this python script you created in VSCode running in a MBP M3 and printing in a LION2X (3DWOX 2X but before rebranding)
After some indent corrections and chatGPT help (I´m a graphic design teacher not a programmer)
it threw me an error related to:
where SEPERATION seems to be misspelled
and after correct it I´ve obtained a file which name ends in 3DWOX same size of the original file..
I´m currently testing but I´m printing another stuff and until it finishes I started writing this memo.
Thanks for the script Carl, let me know if you read this please.
I´ll update with the progress.
