wirlybird wrote:I am running one of the more recent firmwares on my MK2, I think it is like 3.11 or something will have to check. Everything seems ok but I do get corruption in the S3D profile from time to time where I have to delete it and reload.
The one thing that seems to be affected the most is the cooling fan. It either stops adding the line to turn on the fan or it adds an incorrect line. No idea why it does this. I don't think firmware is the issue though since it has done this through a few versions of firmware.
For the last 2 threads I saw about the fan issue, both users had made changes to the firmware settings in their profile that caused the problem. If you're having the same issue where it uses the wrong fan speed command, then you probably did the same thing. Can you attach the profile that you are having trouble with? Should make it easy to confirm.
