First of all, hi to everyone. I am Maarten, a flute maker in Amsterdam. I bought S3d as I am done fiddling with slic3r/ kisslicer settings that I barely understand. Just want to print things. So here is the problem: I can't get the supports off the print. It all is molten together. I think my extruder temperature is too high, either because I have this spool of ABS with a lowish melting point or my thermistor is a bit off. Either way, I do not see a general temperature setting for this plastic. In the process settings I can edit temperature per layer, but does that only affect the current layer or does this setting remain until the next setpoint? And can I make filament profiles?
regards, Maarten
