jwalter007 wrote:
If I hit print Preprep to print, with the model positioned half below the Z, <<OK>>
It shows the paths and looks correct. <<OK>>
If I save that, << you can only save the GCode AND / OR a post precessing format by clicking the " 2 SD-Card symbols, OK? >>
it saves it as gcode << what I say ... >>
and maybe that is just the top half, << that's sure ! see above>>
but I can not bring that
into M3d. << Please help me, whats a M3D, what format it needs. Other formats as GCode when needed you can choose in the Tab SCRIPTS > Post Processing window >>
If I use export to STL << I don't understand what you mean! The sliced model you can never export as STL, thats the same when a bird is able to fly behind itself - worry >>
and bring that into M3d,
it is the full model.
Actually it shows it as just half in the M3D printer but then it says optimizing and then the whole model shows up.
I used to be able to bring the gcode files into M3d
using the spooler,
but that doesnt work for me anymore.
Comments are in RED above.
If "M3D" is Makerbot printer you need their own print format. That you reach by setting in Tab Scripts > Post Processing the spezial format. After slicing and storing the result to anywhere you want, there you will have TWO FILES, one is the GCode-file with the extension *.gcode and the other is the choosen format like *.x3g or what ever. AND this file is what you need.
H.
