How do I make top and bottom layers in multiple processes if I wishto ?
If I eg. want a solid top layer in the 1st process that I can print smaller detail on in the 2nd process.
It could be done before version 4.0 came.
Just add a new process where you want the solid layers. Then set the infill percentage for that process to 100%. Or you can also set that process to print a solid diaphragm every 1 layers (this setting is on the Infill tab, it also makes that section completely solid).
