srlake314
MP Select Mini: ALL Settings for this software???
Good day!
I am curious, it's been over a year since I used this printer and software. I did upgrade the software to the latest today, however, I was curious of any printer specific settings that there are. I have the ones from when the mini has some settings, but not sure if there are any current ones?
Also, I sent a test print, it's connected just fine as I can send the print to the printer, but it starts backing out my filament and never stops, if I stop the print, it continues trying to print, so I wind up having to turn the printer off and then stop at the software.
any ideas?
Re: MP Select Mini: ALL Settings for this software???
The Monoprice Select Mini is in the dropdown box for printer configuration......so the answer to your question must be "Yes, there are printer specific settings."
I assume these are the settings you used for your test print???
srlake314
Yes, indeedy.
Thanks!
