I have a few larger prints that I need to keep lightweight for materials and other reasons.
It be really cool to be able to set the infill for the entire object and be able to beef up infill in certain areas where other objects would mount. What I envision, much like the custom supports would be able to lay in custom blocks under certain mount areas. On a larger part with less infill, forces against the object can be spread out over the area of the object.
So by dropping in a custom block you can change the infill for that blocked out area to be like 20% or something and leave the rest of the part at say 5%.
Thanks so much for reading this!
-Casey
